Local Time 17:39 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Super Capacitor Battery
Posted: 01:49am 13 Aug 2010
Last night on the ABC program Catalyst they covered the super capacitor/battery being developed by the CSIRO.
Very interesting article.
You can view the short video here
http://www.abc.net.au/catalyst/stories/2981298.htm
Pete.
Posted: 11:54am 13 Aug 2010
Hi Pete
Yeah I saw that too. About 2 years ago I was lucky enough to attend a talk by one of the senior CSIRO members involved with the super batteries development, very interesting. The battery is small, but has the power of a much larger battery, and a longer life. And it still uses the same old lead acid configuration we have been using for the last 150 years, plus carbon for the super capacitor. No exotic minerals needed.
adonis
Posted: 06:07pm 19 Aug 2010
I agree, very interesting!
in a comment below the article someone say that capacitors are inefficient (when charged). is that true? i thought they could be very efficient. not only that they can deliver high power but also as energy storage devices.
i thought that capacitors is a good candidate as the next generation of batteries.
please set me straight!
VK4AYQ
Posted: 12:19am 20 Aug 2010
Hi Adonis
I experimented with caps in parallel with batteries years ago and the results where quite good, only the making of them was a bit difficult, and they where very large, this new development looks promising from a size point of view.
I found it was quite efficient as there isn't a voltage differential loss as in a battery, it made the regenerative braking more effective, due to the ability to absorb energy easier than a battery, and the battery ran cooler as the spikes of energy came from the capacitor and the steady load energy came from the battery. My system was low voltage max 60 DC so I think that they would be more effective on a higher voltage system as the stored energy would be much greater for the same size capacitor.
All the best
Foolin Around
