Local Time 16:59 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Reed switch
vasi
Posted: 01:26pm 04 Apr 2010
Which one is suitable for anemometer?
See them here.
Thank you!
Elvish name: Mablung Miriel
Beyound Arduino Lang
Janne
Posted: 01:39pm 04 Apr 2010
I'd say none. I've had 2 reed relay anemometers, and in both the reed's failed before lasting a year. Optical system works much better in the long haul.
If at first you don't succeed, try again.
My projects
vasi
Posted: 02:32pm 04 Apr 2010
  Janne said   I'd say none. I've had 2 reed relay anemometers, and in both the reed's failed before lasting a year. Optical system works much better in the long haul.
Ok then...
I have this option:
TLE4905L Hall sensor, digital output, unipolar (or maybe TLE4935L bipolar).
2010-04-05_003213_TLE4905L.pdf
Posted: 09:47am 08 Apr 2010
Hi Vasi,
A hall sensor will work ok but some need an opamp or comparitor to set the signal level for use with a micro as they dont switch to 0 level and the micro will not detect the level change.
Most will give a level change of +/- of half the supply voltage.
I used a photo interupter same as janne said.
If you can find an old bubblejet printer some of them have very good photo interupters in them.
There was a thread a few weeks back that i posted some information to, i think it was called Aneomometer build time ... or something simular.
Have you worked with Hall effect sensors before?
Pete.
vasi
Posted: 10:07am 08 Apr 2010
  Downwind said   Hi Vasi,
Pete.
Never before. I know this one have a digital response (is not analogue). I will look for your thread, thank you.
Vasi
