Local Time 21:13 22 Jun 2026 Privacy Policy
Forum Index : Electronics : Help to ID a Linear Regulator
sPuDd
Posted: 07:57am 03 Apr 2010
G'day all,
we use this particular species of 13.8Vdc 5Amp power supply a lot in the security industry. The brand has a very good reputation and is usually only killed by abuse. Normally we just replace a faulty unit with a new one and charge accordingly, but I thought I'd open one up and see what makes it tick.
This one has a faulty regulator as it outputs full rectified voltage. I have tested everything else and compared it to another unit.
However, the regulator is a TO-220 7-pin package and the markings have been deliberately scrubbed off. I searched for a few hours on Google for anything that would fit the bill, but alas only switching regulators come close. This PSU is not designed as a switching regulator as it lacks the necessary inductor, rectifier and output caps etc... it’s just an ultra low drop out series reg.
Anyone got a clue as to what it is?
A new one of these is ~$400
sPuDd..
It should work ...in theory
Posted: 08:05am 03 Apr 2010
I think its a crime the way manufacturers deface components so they cant be identified.
I'll have a look though my component draw for any 7 pin regulators and let you know.
sPuDd
Posted: 10:17am 03 Apr 2010
Thanks Gizmo,
I'm thinking I might mod the unit and fit an LM338T which is rated for 5amps continuous and 7amps peak in a TO-220 package.
sPuDd..
Bryan1
Posted: 10:53am 03 Apr 2010
G'day Spud,
Off memory I got some samples and the guys at the uni made me a constant current supply for my cnc power supply, I do reckon these had 7 pins and the chip might be the one. Unfortunately being late and a few ales under the belt it will be best to look in the morning.
Cheers Bryan
Edit: by the way is there an inductor on the board as this will give me the clue that I'm on the right trackEdited by Bryan1 2010-04-04
Posted: 11:43am 03 Apr 2010
What is the 2 components either side of the vreg.
I am guessing they might be bypass transistors.
Pete.
WindChopper
Posted: 04:12pm 03 Apr 2010
Take a look at
http://www.national.com/pf/LM/LM2678.html#Overview
Might be the same family
Russ
sPuDd
Posted: 02:11am 04 Apr 2010
Bryan,
no inductor - its a series regulator.
Pete,
the side devices are twin schottky packs that form two half wave rectifiers.
Russ,
that was one of the devices I found during my search, but its a switch mode device which will not do.
I'll trace out the circuit then mod it for an LM338T. I've got several of them laying about. Just thought someone may have seen a 7-pin TO-220 series reg used somewhere else.
sPuDd..
