Local Time 16:59 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Latronics PVE1200 Schematic?
BjBlaster
Posted: 01:28am 23 Mar 2010
Hey Guys we had some terrible weather here in Perth last night, and my gutters overflowed and filled the eves up and then poured through the light fitting into my grid fed inverter whilst it was on
Just wondering if anyone has the schematic and or service manual for such a beast? I think the power stage is a miss, but can't see what should be feeding it from the micro....
Bj
Check out my projects here in:
Bj's Shed
Posted: 03:49am 23 Mar 2010
Hi Bj,
I damaged my PVE1200, from overvoltage.
Water would most likely screw up the logic, and send the wrong signals to the mosfets. Probably have some fused devices. There are mosfet drivers on the micro outputs. 8pin dip's.
Mine took out 7 mosfets. I replaced them, but still no go. Sent unit back to Latronics, as there were additional problems that I was unable to trace. I could not get ccts either.
I opted to get them to fix it. Quote was under $300, and included warranty. I only sent back the electronic module. I figured, No point in sending complete unit, as freight was going to be a problem.
A phone call to Latronics would be the go.
Gordon.
neil0mac
Posted: 10:59pm 23 Mar 2010
Gordon,
Other ways to damage a Latronics Inverter besides 'over watts'?
Over amps?
Posted: 02:30am 24 Mar 2010
Hi Neil0Mac,
In my case, it was not power related, as the inverter had not yet connected to the grid.
I doubt that Amps would play a part, as I have seen the PVE1200 supply over 1500W back to the grid, before current limiting. BTW, I believe that 20A is the current limit.
Units have thermal protection as well, that reduces the current limit.
I believe that the units if operated with an external voltage input limit, are well protected.
The unfortunate aspect is the uncontrolled component. Water messes with most things electrical.
Gordon.
BjBlaster
Posted: 11:59am 24 Mar 2010
Well I fluked it :) I changed the driver that fed the two fets that leaked obvious smoke... and it's working fine again
thanks for your input though!
Bj
Bj's Shed
KarlJ
Posted: 06:12am 27 Mar 2010
BJ blaster
now should call you lucky, nice one!!
Who did your install? and clean the gutters and put a hood over the top to prevent any possibility of it happening again
next time might no be so simple
Karl
BjBlaster
Posted: 11:45pm 28 Mar 2010
  KarlJ said   BJ blaster
Karl
The gutters where squeaky clean, it was just we had our months railfall in 20 minutes, and hail the size of tennis balls. It was the worst storm in 50 years... No one was ready for that
A bloke from work had to start drilling 20mm holes in his back wall to get the water out of his cavity because the water was coming out of the 300mm high power points inside his house from the gutter overflow. Perth had never seen anything like this.. well in our lifetime anyway.
So I removed the light socket that was in the eves above the inverter and filled in the hole. Now at least it can't funnel into the inverter if the eves fill up again
Bj's Shed
KarlJ
Posted: 09:16am 29 Mar 2010
i was here, one of my Volvos was suspected drowned
(but AOK)
the other which had literally been delivered hours prior to the storm was outside for 1/2 the hailstorm.
Damage is noticeable if you look carefully but for $1000 excess I think I'll be living with it.
I did tell the Perth locals to look out, I was coming!
Karl
