Local Time 16:57 04 Nov 2026 Privacy Policy
Forum Index : Electronics : My half-step driver is working :-D
vasi
Posted: 03:11pm 15 Jan 2010
My stepper driver is working and... is selling in Czech Republic. This prove that firmware is working right (the manufacturer is producing it with two firmware options - half and full step). I'm providing only half step firmware but having the source (C, Pascal and JAL), anyone can modify it.
Congratulations to them!Edited by vasi 2010-01-17
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 06:08pm 15 Jan 2010
Looks good Vasi.
You must be happy with the results.
I just finished a 08m picaxe bipolar stepper driver board to run the steppers used in bubblejet printers (4 wire steppers) although direction is done in software as the 08m dont have the extra input like the pic for direction and step control.
You can pic that to if you want, and then you will have a bipolar version as well.
I tend to find more bipolars used than unipolar.
Only problem with using a 8 pin chip with bipolar you cant get half stepping as the pins are shared by both coils.
Pete.
Posted: 09:44pm 15 Jan 2010
Well done Vasi.
Good work, very neat.
vasi
Posted: 10:03pm 15 Jan 2010
Thank you all!
Of course I'm not involved in that in any way . Anyone can use it for commercial purpose but I will be glad to have an image or a link to their work (I discovered it by looking at google analytics - maybe they had no courage or interest to "throw" a link...).
Vasi
vasi
Posted: 10:09pm 15 Jan 2010
  Downwind said  ...I just finished a 08m picaxe bipolar stepper driver board ...
You can pic that to if you want, and then you will have a bipolar version as well...
Hi Downwind,
You published it?
Vasi
Posted: 12:03am 16 Jan 2010
Not Yet Vasi.
Still waiting for the ink to dry.
I need to build it first to check if all works well before i post it on 4m as well as get all the files together thats needed.
I will post a message here when i post it to the 4m so you dont miss it.
Pete.
Posted: 05:40am 17 Jan 2010
Hi Vasi,
I posted the Bipolar stepper driver circuit if you would like a look.
Its at ......Bubblejet to uv led pcb scanner ..... Thread in Electronics.
Pete.
vasi
Posted: 08:31am 17 Jan 2010
  Downwind said   Hi Vasi,
Pete.
Thank you Pete, I will study it!
Vasi
