Local Time 16:05 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Piclog viewer
Posted: 11:27pm 19 Sep 2009
I have simplified the piclog viewer I have been looking at my own data with. Others may also find this program useful.
The program is a self extracting folder. The small application needs to be run and then the Piclog_viewer program is placed in the same folder as the piclog program, and allows click viewing of piclog data files, in the logs directory.
This link will download the self extracter.
2009-09-20_091438_PicLog_viewer.zip
You need to save, or run and then extract the file from the folder. Move or copy the extracted Piclog_viewer to the piclog folder.
If U get an error 76 then the program has not been moved/copied into the piclog folder correctly.
windman1000
Posted: 03:26am 20 Sep 2009
Very Nice
I was hoping to get this after seeing it on one of your post in the past.
works and looks great
Posted: 04:03am 20 Sep 2009
Hi Windman1000,
now it should be an easy task to view your data and post some screen dumps of typical days.
Gordon.
