Local Time 16:04 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Cheap bulk components
Posted: 10:37am 19 Sep 2009
Hi All,
Is anyone interested in 25 x relays being sold as surplus stock.
They are a latching relay in a DIL package ( will fit in a 16 pin ic socket) with a 3 volt coil rating DPDT 2Amp contacts.
P/N :- HFD2/003-S-L2
Manufacture :- Hongfa
Great for use in low power circuits. They have 1 set of coils for latch and a second set to unlatch.
Once latched/unlatched will remain in that state with power removed till power is applied to the unlatch/latch pins.
A pulse of 2-4 mS is required to latch / unlatch the relay
I had trouble finding the data sheet for this relay but on Datasheet.com they show single coil and other voltage relays but not the L2.( search for HFD2/012-S-L2)
The coil resistance is 60 ohms.
Au $ 25.00 + postage (for 25 relays) (check your Jaycar catalogue for simular $12.95ea.) (price to forum members only)
I intend to place a lot of odd components in 10-100 lots on eBay to help clear surplus stock from a supplier that I have a good working relationship with.
There is very little profit in it, but I just hate to see things sit there at a cheap price, with those of us that can do with some extra bits in our junk box at a good price and not miss out.
I don’t know if it is acceptable to offer things for sale in a range of components on this forum or is there a section that this more appropriate for?
If it is requested I can post more items of bulk lots for sale with the prices, but do not wish to use the forum as an advertising means for lots of stuff that may be of no interest to members.
There is things that I make use of like, PCB mount screw terminal blocks that will clip together as integral blocks, header pins in various pin counts. 7seg 4 digit led displays, 12 meg crystals, LM833 dual op-amps, BC556A PnP transistors (TO92), smd 8 meg ceramic resonators, to name a few,
Don’t ask for a price on 1 item as all sold in bulk lots.
There is a lot of weird valued components but may be of use to someone.
All items are till stock cleared only.
Downwind.
