Local Time 19:53 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Charging Batteries
Ricco
Posted: 05:05pm 28 Aug 2009
Have any of you experimented with John Bedini's radiant energy battery chargers? Supposed to rapidly strip the sulphate off battery plates - rejuvenating them, even ones that have been used for door stops for years.
The Bedini version needs a lot of coil winding however there is now an easier way go to -> http://imhotepslabs.freeforums.org/viewtopic.php?f=3&t=6
for info on re-arranging the coils inside a standard computer cooling fans. It uses one 12v battery to drive two coils in the fan via a 2N3055 (these little fans have embeded magnets in the rotor just like F&P rotors) and "harvest" the back EMF + radiant energy off the other two coils. Imhotep has lots of YouTube videos showing you how to do the modifications. It is a bit fiddly unsoldering and removing the ends of the coils off the terminal pins. I have attached a file of Imhotep's circuit, check out his web site because there were a couple of variations and I am not sure if I have the latest one. As soon as I "found" his site I was wondering if a reconfigured F&P might work even better than a tiny computer fan coil set up. As with the Bedini motors it is not self starting, needs a manual spin up but will continue to run OK after that.
Ricco.2009-08-29_025219_Basic_CCT.zip
Ricco
sPuDd
Posted: 10:45am 30 Aug 2009
Or just use one of these: Battery Zapper Mk III
sPuDd..
It should work ...in theory
Dogalot
Posted: 04:10am 03 Apr 2013
I am interested in trying to make one...
