Forum Index : Electronics : A simple charge controller
| Russell Newbie Joined: 16/08/2009 Location: United StatesPosts: 10 |
Just put one of the charge controllers together and having some trouble. As soon as I apply power,the R1 12k frys. It all looks good, no dead shorts or connections crossed. Using 1/4 watt resister, don't know if that is correct or not. thanks for any help. |
| Robb Senior Member Joined: 01/08/2007 Location: AustraliaPosts: 221 |
What are the colour bands on your '12k' risistor? |
Hi Robb looks like brown,red,black.gold. Thanks |
Thats a 12 ohm resistor, not a 12k ohm. It should be brown red orange gold/silver ( the last one is the tollerance ) http://www.thebackshed.com/Windmill/Docs/ElectricComponents. asp Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
thanks Glenn I will try it with the wright resistor |
Ok so what colour is your 3.3k. I'm thinking it must be wrong too to be able to smoke the 12 ohm above it. |
Yes its wrong to, Got a good lessen in reading color codes on resistor. Going to spent some time tonight swapping out resistor. Bear with me guys,got a lot of good idea's but little slow on the learning curve. |
| timbo Newbie Joined: 17/08/2009 Location: United StatesPosts: 2 |
I'm trying to find the parts to put one of these together (24 volt version) and I have found everything but the DB139. I have tried several searches for it and subs but haven't found it. Everything else I have found at newark.com Can anyone tell me where to find it? Or a sub I can use? Thanks |
Timbo try this place they seen to have everything under the sun. http://www.mouser.com/ And timbo its a BD139 not a DB, I think its a miss print on the veroboard layout. Also the R1 12k on the veroboard layout is marked as a 10k, I think this is correct but Im a Newbie to, maybe some one with more know how got confirm is. |
The sections of the opamp are transposed too. 1/4 and 2/4 are swaped on the layout. It dosn't matter apart from creating confusion . |
Thanks for the help. Now with the correct part # I found everything I need at Newark for about $14.00. Any idea what kind of power this will handle? From looking at the scematic it looks like the relay needs to be able to handle the power. I hope to get 500W out of my generator so I better be sure I have 40A relay. |
It works! Amazing what happens when you use the right parts. Thanks for the help, next thing is to hook this up to my turbine and start charging batteries. |
Hey Russell, happy to hear it. You got to watch those resistor color codes. The 5 band resistors are a real nightmare. Timbo the output is limited by the relay, your right. The BD139 will drive a typical 12v spot light relay, anthing bigger and you could use a smaller relay to switch a bigger relay. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| readyakira Senior Member Joined: 17/07/2008 Location: United StatesPosts: 114 |
Can ya post the link to the controller info you used? It sounds like a relativly simple circuit you designed... Don't you think Free/Renewable energy should be mandatory in new buildings? |
readyakira the link is http://www.thebackshed.com/Windmill/articles/TL084-Controlle r.asp this is the same place that this form is on. |
