Forum Index : Electronics : Bluetooth module recommendations.
I tried a bluetooth module to let me connect my amp and speakers to my TV. It works, but has this very annoying "The bluetooth device connected successfully" every time I turn everything on. And If I power down the TV, I get a "The bluetooth device is ready to pair". Can anyone suggest a module thats a little less talkative? All I need is something that can connect to the TV, with line level outputs. I did try using the optic audio output of the TV, but the TV volume control has no control over the output volume and I'm using a old school amp, no volume remote. There are no other audio outputs on the TV unfortunately. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
