Local Time 05:23 06 Aug 2026 Privacy Policy
Forum Index : Electronics : Proximity detector
larny
Posted: 09:30am 21 Feb 2026
Does anyone know where I can find a circuit for a Proximity detector?
Any help will be appreciated.
Posted: 09:54am 21 Feb 2026
Depending on the application a basic laser distance sensing module may be suitable.
The circuit is nothing more than I2C data and clock plus 3.3V and ground.
Very cheap on AliExpress.
Example MMBasic code for a VL53L0X on a PicoMite.
For other MMBasic platforms the only difference is likely to be the way I2C is setup. The relevant manual will have the details in the I2C Appendix.
'VL53L0X LASER distance using PicoMite System I2C on I2C channel 1
'change all I2C to I2C2 if System I2C is on channel 2
Dim Integer dist
Const VLaddr=&H29 'VL53L0X I2C address
  VL53L0X
  Print dist;" mm"
  Pause 2000
Loop
Sub VL53L0X
  Local Integer dst(1)
  I2C write VLaddr,0,2,0,1   'trigger VL53L0X measurement
  Pause 75  'allow time to perform measurement
  I2C write VLaddr,1,1,30    'prepare to read
  I2C read VLaddr,0,2,dst()  'get the data
  dist = (dst(0)<<8) + dst(1) - 20  'assemble the bytes and subtract the 20mm offset.
End Sub
Edited 2026-02-21 21:57 by phil99
