Local Time 11:41 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Quick review - PowerHouse" 12v 10A charger/supply from Altronics
zeitfest
Posted: 10:38am 07 Dec 2025
I wanted a 12v battery charger with some grunt, and a powerful 12 supply
was going to be useful as well so I bought a 'PowerHouse' charger as at
Altronics. There are two models, one charges at 4A and one at 9-10A, I bought the 10A version and it arrived quickly.
It is apparently processor controlled  and give different charging profiles for
standard lead-acid, AGM, cold battery, LiFePhosphate,  and also a mode to act as a 12v/10A power supply.  Plug into the mains, the bespoke LCD display lights up and you can then cycle through the options using the press switch on the front.  There is also a battery charge state report mode which is powered by the battery itself. The AGM mode is an eye-opener, I didn't realise AGM had special requirements, and the cheap chargers often don't have the option.
So far I have charged a 100AH 12V lithium iron-phosphate battery, it was pretty straightforward and charged at a healthy 10 A before tapering off. It runs fairly warm.
The package has the charger, some useful cables, and an instruction booklet.
The instructions are a bit hit-and-miss. One part says to connect the cables to the battery before plugging into the mains (good safety for lead-acid - prevents sparks near the battery) but other parts cite a different order.  But the operation is pretty
intuitive - assuming common sense ! - so it is a minor point.
There are safeguards against reverse polarity and so on which is good.
One of the cables has a useful blade fuse holder built-in. Watch the polarity
of the connectors, it is possible to connect red to black and vice versa - not
a good thing to do... errm, the fuse holder works quite well   .
It is going to be really useful, especially to occasionally keep a car or auxiliary  battery charged, as well as using it as good 12v source.
Edited 2025-12-18 10:02 by Grogster
Chopperp
Posted: 12:56pm 07 Dec 2025
Is this the one? here
ChopperP
zeitfest
Posted: 03:40am 08 Dec 2025
Yes but it was quite a bit cheaper when I bought it
Chopperp
Posted: 05:31am 09 Dec 2025
OK
Does it remember it's settings if there is a power interruption, or does it play dumb when the power is restored?
ChopperP
zeitfest
Posted: 08:52am 09 Dec 2025
It remembered  when I set it to LiFePhos mode, ie originally it was in PbAcid mode and I set it to LiFePhos to charge the Li battery.  The next day I resumed charging the  battery and the charger powered up directly in LiFePhos mode which was good. It states that it can be permanently connected, so I guess it is designed to keep the settings OK.
The battery charged up fine, the current was at around 10A for quite a while and then tapered to a very low level at 14.4 v AFAIR. I then used it with a kmart "anko" inverter and some LED bar lights, for lighting in my dim garage (no power) while I changed the oil on my car. No worries !
Edited 2025-12-09 18:53 by zeitfest
zeitfest
Posted: 09:04am 09 Dec 2025
That's funny, the description of this thread has been truncated . WTF ??
Posted: 05:38am 10 Dec 2025
I didn't truncate it.
I doubt Gizmo did.
I suspect it is a bug in the forum software.
I will run a test.
Chopperp
Posted: 01:30pm 10 Dec 2025
  Quote   so I guess it is designed to keep the settings OK
Thats good to know. Some don't which is annoying.
Brian
ChopperP
Posted: 12:02am 11 Dec 2025
  zeitfest said  That's funny, the description of this thread has been truncated . WTF ??
Hi - can you please state what the rest of the title was supposed to be, and I can probably edit your original post, to put it back in the thread title.
I'm running a test on this on the OTHER STUFF forum, but once that test is complete....
zeitfest
Posted: 12:29am 11 Dec 2025
Thanks Grogster,
the rest of the description AFAIR was something like
"PowerHouse" 12v 10A charger/supply from Altronics
Not much point posting reviews I guess.
Posted: 02:36am 11 Dec 2025
OK.
I for one, like reading reviews.
Posted: 02:45am 11 Dec 2025
  Quote  posting reviews
That might be the key to it. Perhaps Gizmo has a filter to detect companies posting fake reviews as a way of getting free advertising.
Posted: 05:34am 11 Dec 2025
Yes, that is a possibility.
davros
Posted: 03:08am 12 Dec 2025
bought this recently:
https://www.amazon.com/YHCHKJ-Automatic-Maintainer-Motorcycles-Batteries/dp/B0F48MK6W2
