Local Time 16:56 22 Jun 2026 Privacy Policy
Forum Index : Electronics : picaxe programing elmer
grandpam
Posted: 12:30pm 08 Jun 2009
Hi I am new to the picaxe and am working my way through the tutorials. I would like an elmer to answer questions and give advise on a one to one basis.
I find forums good but slow.
Hope someone is willing to share their knowledge.
Phil Moorey
pmooreyca@gmail.com
Posted: 01:17pm 09 Jun 2009
What aspects of programming will you be needing a hand with.
Gordon.
grandpam
Posted: 06:27pm 09 Jun 2009
Hi Well currently i have managed to write a simple program using the simulator comparing two sensors as a differential thermostat. It works but when comparing it with other similar programs they seem to average out the readings and I don't know enough to understand why?
Mine works on the simulator.
Also find variable registars confusing. They are address points but the application of I am not sure.
SparWeb
Posted: 02:41pm 12 Jun 2009
Perhaps you could show us the code and tell us which Picaxe you are using?
In the programming editor, you can select text, copy to clipboard, and paste into the the text box here in your next forum post.
Will you datalog from a windmill? Are you interested in the PicLog kit?
Steven T. Fahey
grandpam
Posted: 07:29pm 15 Jun 2009
Hope this works. This is a program for a differential solar collector pump. The chip would be a 18x and will used lm225 sensors when they arrive.
This is programmed so that the outside sensor exceed 150 degrees the pump shoots off, also when the inside sensor matches the outside sensor it also shuts off.
main:
readadc 1,b0 ; a1 outside sensor
; a2 inside sensor
readadc 2,b1
b1 =b1+3
if b0 > b1 then top
low 0
goto main
top:
if b0> 150 then bot
high 0
goto main
bot:
low 0
goto main
Posted: 01:05am 16 Jun 2009
The code above will work, but for more complicated programs, you may define the registers, to variable names like below, and also define constants to make the program more readable. you can change a value in one place, and all references will change as well.
#picaxe18X
Symbol outside_temp = b0
Symbol inside_temp = b1
Symbol offset = 3
Symbol Max_temp = 150
symbol pump_control = 0
main:
readadc 1,outside_temp
readadc 2,inside_temp
inside_temp = inside_temp + offset
if outside_temp > inside_temp then pump_on
pump_off:
low pump_control
goto main
pump_on:
if inside_temp < max_temp then
high pump_control
else
goto pump_off
endif
goto main
end
This is the tip of the proverbial iceberg with these micros.
Gordon.
grandpam
Posted: 03:09am 16 Jun 2009
Yes I can see how defining will make things easier but
I find it difficult to follow the flow of the program especially the references to low pump and high pump.
Can you flesh out more detail there?
Kind of difficult to admit not understanding, especially on an open forum but sure appreciate the assist.
Phil
grandpam
Posted: 03:53am 16 Jun 2009
further note
i am familiar with the "if then " instruction as it gives a flow to the instructions but seem lost without it
Phil
Posted: 02:22pm 16 Jun 2009
I doubt that this Forum is the best platform to teach a programming language. You may need to find a good book on Basic programming, or enrol in the education system in a course related to this field.
The program I posted above is pretty clear. On a micro application, there will always be the specific output pin control commands. Subroutines could have been used for the pump ON and pump OFF operations as well. The low and high commands are effectively functions that are called, with the pump_control value being which switch to activate.
You will need to become familiar with the full programming function set and the syntax for each. The picaxe programming application has a very good help section. You have started with the picaxe18X. The picaxe08M would be a better option for this dedicated application.
I am no expert, but have found that these micros are pretty forgiving, and can be reprogrammed hundreds, or thousands of times. The simulator helps as well in most cases. Try and place visual indicators on digital inputs and all outputs in your final pcb layout. It is possible to damage outputs if you accidently short 2 outputs together with a probe, in an effort to measure logic levels. I have LED indicators on the comm port as well.
The picaxe are very versatile and for most applications with timing, logical sequencing, low resolution analogue mesurements and limited PWM output. I have used a single device for many diverse applications. I now have the picaxe14M and the picaxe 28X2 that I will be finding uses for. As long as the limits are not exceeded and the program is well debugged, then all is good. Some bugs are still able to get through the programmer that can cause a program to stop unexpectedly. This is probably why the devices are not to be used for life support systems.
Gordon.
grandpam
Posted: 01:02pm 18 Jun 2009
Yes I agree that this forum is not the place to go into detail however that was not my intention. I was seeking an elmer that would be willing to answer questions and offer tips like you have done and others do on other forums.
I appreciate the suggestions that you have provided and will continue to learn how to master the power of the microchip.
Grandpam
SparWeb
Posted: 06:57pm 18 Jun 2009
You could try using a flowchart. I find it helps sometimes, though I've been programming stuff for a while and usually skip that step. Back in school these were use a lot to illustrate program flow and structure.
By the way, what's an "elmer"? I keep thinking of Elmer Fudd, but I wouldn't take advice from him! :^)
Steven T. Fahey
grandpam
Posted: 02:18am 19 Jun 2009
Whats and elmer? In ham radio there are experienced hams that the new fellows can go to and ask questions and receive the benefit of their experience. Its a great system and even after all these years we still turn to those with experience and learn from them.
grandpam
Posted: 08:26am 12 Nov 2009
Did you ever find youre "elmer"??
I understand how hard it can be to get a little help with electronics and programming to learning the basics.
It is a pitty that some give up through a few simple problems and not understanding the solutions.
Did you manage to get your project to work?
Pete.
Bryan1
Posted: 10:21am 12 Nov 2009
I think what the op wants is a picaxe version of this ELMER 160. Which is a great learning curve into PIC microcontrollers to utilize their full power instead of an interpreter that the picaxe is which is one step up from the basic stamp.
Sorry guys if you think I'm knocking the picaxe again but if you guys are happy with it so be it. The picaxe is great for getting into microcontrollers but the big problem exsists from the days of the basic stamp. When a person wants to move on from the picaxe or basic stamp they are back to square one as both of those interpreter platforms dont use encourage the user to consult the datasheet and learn about the pic's file structure and registers. A basic structured compiler like PBP ( pic basic pro) or Oshonsoft Basic IDE does use the pic's registers in the programs and is much more powerful for programming.
Cheers Bryan
