Local Time 13:35 04 Nov 2026 Privacy Policy
Forum Index : Electronics : 4kW inverter recs?
flyingfishfinger
Posted: 06:02pm 12 Nov 2024
So as I posted about a couple months back, we managed to blow my inverter (Xantrex 4048). Without documentation I haven't been able to fix it, so I'm in the market for a new one.
I'm looking for inverter only, no MPPT / charging - and I don't want any of the cheap stuff from China... What recommendations might folks have for this class of device, 48V?
Cheers,
R
Edited 2024-11-13 04:21 by flyingfishfinger
Revlac
Posted: 09:23pm 12 Nov 2024
Only one option then, Build one.
Cheers Aaron
Off The Grid
Godoh
Posted: 01:05am 13 Nov 2024
One OZ inverter manufacturer that made what you are after has gone out of business. Latronics inverters were just that, they were simple inverters, no charger.
Unfortunately they decided to close down this year.
If you can find one of their inverters it would do what you want.
As Reviac says making your own is an option. You can get powerboards from Aliexpress and Ebay that are cheap and easy to fix. But you need to add the transformer a choke and a few other bits.
Or make one on the designs folks here have made
good luck
Pete
Solar Mike
Posted: 01:57am 13 Nov 2024
I have purchased a number of HF inverters over the years from "Reliable Electric" on Aliexpress, not one has failed and they will put out the advertised power.
Reliable Electric
Mike
analog8484
Posted: 04:35pm 13 Nov 2024
Why not the newer version (Schneider SW4048) of the same inverter?
Clockmanfr
Posted: 08:58am 14 Nov 2024
  Godoh said  One OZ inverter manufacturer that made what you are after has gone out of business. Latronics inverters were just that, they were simple inverters, no charger.
good luck
Pete
Godoh,
Still selling the OzInverter 2nd edition make your own 6KW OzInverter book, until i run out of stock.
Becuase of the worldwide customs duties and recent increase in import duties/ tarrifs, I have stopped supplying the 3 bare PCB's, its just very time consuming and not cost effective.
However, if you do order the Book i will email the XGERBER files for each of the 3 PCBs.
I am not a comercial buisness and never was, and supplied everything at cost becuase so many people like 'Oztules' 'Warpspeed' etc, helped me.
https://www.bryanhorology.com/ozinverter.phphttps://www.bryanhorology.com/ozinverter.php
Edited 2024-11-14 19:00 by Clockmanfr
