Local Time 14:16 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Victron MPPT
Murphy's friend
Posted: 02:46pm 17 May 2024
Anybody thinking of buying a Victron MPPT might watch this first:
youtube
Murphy's friend
Posted: 02:49pm 17 May 2024
youtube
I give up posting URL's - sorry, the forum never does mine
-dex-
Posted: 04:11pm 17 May 2024
https://www.youtube.com/watch?v=9LGiwhAMLn0
rogerdw
Posted: 12:14am 18 May 2024
I was surprised to see Andy being so rough. Even our own Mab1 knew you need to use a holesaw to release the inductors and cut across to avoid the capacitors.
There was a link in the comments to another attemt here ... where the guy used a holesaw. A much more civilised effort.
Cheers,  Roger
Godoh
Posted: 02:08am 18 May 2024
Definitely built to be a throwaway device. Potting the capacitors is a rotten trick.
I would think that a controller that costs as much as they do would be at least repairable.
Will never buy another one. I have one in service out of 3 now.
Pete
mab1
Posted: 07:02pm 18 May 2024
  rogerdw said  I was surprised to see Andy being so rough. Even our own Mab1 knew you need to use a holesaw to release the inductors and cut across to avoid the capacitors.
Yes, it did seem more like a rant about victron than a serious attempt to repair to me. Maybe he's better at making u-tube vids than watching them. I did watch his vid about using a heat gun, and saw some opinions that the heat gun method didn't work with the bigger units, and saw the one with few words using the holesaw which seemed the course to follow.
I'm still smarting a bit that it went belly up just when i thought I'd succeeded   - i was all poised to do a victory post on here when it went dead.  but at least my careful disassembly means all the fets and caps and inductors still have their legs and could be re-purposed (i haven't tried confirming which component is shorted - I'm still too tempted to throw it at the wall).
Edited 2024-05-19 05:29 by mab1
rogerdw
Posted: 03:05am 19 May 2024
  mab1 said  Yes, it did seem more like a rant about victron than a serious attempt to repair to me. Maybe he's better at making u-tube vids than watching them. I did watch his vid about using a heat gun, and saw some opinions that the heat gun method didn't work with the bigger units, and saw the one with few words using the holesaw which seemed the course to follow.
I think you're right about him wanting a rant  ...  another of his earlier videos came up here and he was clearly unimpressed with Victron, even before he started.
Rightly or wrongly I have no idea  ...  though reading a lot of the comments from many of the fan boys in some Victron groups, it may be more an annoyance at their elitist attitudes (the fan boys, not Victron itself)  ...  because most of them rub me up the wrong way too.
I'm sure their gear is generally pretty good and better than a lot  ...  but it's not the only option that's for certain.
  Quote  I'm still smarting a bit that it went belly up just when i thought I'd succeeded   - i was all poised to do a victory post on here when it went dead.  but at least my careful disassembly means all the fets and caps and inductors still have their legs and could be re-purposed (i haven't tried confirming which component is shorted - I'm still too tempted to throw it at the wall).
Yeah, that's gotta hurt  ...  especially after all the effort you've put in. Still it may be worth having another look once you've had a bit of a break from it and the pressure is off with your neighbour having bought a replacement. Surprising how often a fresh look opens up new avenues to explore.
Cheers,  Roger
