Local Time 12:59 22 Jun 2026 Privacy Policy
Forum Index : Electronics : I'm back! (Also looking for a specific IC)
Haxby
Posted: 12:06pm 29 Jun 2023
Hi all, it's been a while since I've been on the forum. My job has been getting in the way of playing with inverters.
I'm designing another inverter PCB at the moment that needs a very fast "opto" isolator.
I recall there was talk on this forum about a specific IC that worked exactly like an optoisolator but it ACTUALLY wasn't an opto component on the inside. I think it used magnetics or capacitance or some other trickery. The best thing about it were two qualities: it was bloody fast compared to a real opto, and it was able to withstand reverse current. It was special also because if I recall correctly, I believe it also didn't need a 5v power supply at the pseudo LED side of the chip. Whatever trickery it used to get the signal across the barrier, relied on getting the transmit power from the signal itself. Much like an optocoupler led would, but much faster.
I've looked through the forum but can't find the specific thread again, and don't recall who put me on to it. Any ideas?
Solar Mike
Posted: 09:39pm 29 Jun 2023
Are you wanting the Mosfet gate driver version or just a replacement for a standard opto-isolator.
Mike
Haxby
Posted: 11:06pm 29 Jun 2023
Just a replacement for a standard opto.
Haxby
Posted: 01:45am 30 Jun 2023
Ah found the discussion:
here
