Local Time 16:39 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Plasma cutter error
Ellen
Posted: 10:46am 12 Mar 2022
The reason I joined here was to ask if anybody had a good knowledge of Chinese Plasma Cutters.
I have a "Cut 50"  that refuses to start. when I pull the trigger a buzzer sounds ,I hear a relay click and the red temperature warning light comes on too and it will not start cutting .
Does anybody know please where the sensor for this might be attached ?
I would assume on the finals but sometimes they put them on inductors and transformers and the like . I have looked but nothing is obvious.
I know about the spark gap start setting and I'm pretty sure its right.
johnmc
Posted: 10:42pm 12 Mar 2022
suggest you check linuxcnc forum for plasma information.
cheers john
johnmc
Ellen
Posted: 03:21am 14 Mar 2022
Thanks joined that and we will see .
