Local Time 20:15 22 Jun 2026 Privacy Policy
Forum Index : Electronics : PCB design to my door in 6 days
poida
Posted: 06:38am 28 Oct 2021
I have a need for a sort of dumb, slow is OK, close enough is good enough
power supply that can do 10 or 15 Amps at up to 100V
55V at 10-15 Amps for inverter testing
100V at 10 Amps for mppt testing
54.6V for ebike battery charging at 5A or 10A or even at 1C which
would be 20A
I based it on the mppt but only need 1 FET and one diode.
It incorporates the Hall type current sensor short circuit protection
I have just developed.
Runs on a Nano (of course) which lets me make it more than a charger or
simple PS. It can do constant power if I want (mppt testing...)
Only bits I needed to buy were the Allegro current sensors.
6 days from uploading to jclpcb to having the result in my hand.
It looks like this.
the actual pcb is:
the result will be:
the schemeo:
Schematic_dc-dc supply_2021-10-28.pdf
It's not really special or warranting a post here.
I just wanted to tell someone that I find it astonishing to have a
pcb for my power supply within 6 days.
No hassles. Just $38 for 5. This is cheap and good quality and fast.
This completely nukes any idea of home brew pcb production.
The PS will have a 20x4 LCD showing
Vin   cc/cv
Vout  Iout
Vset  Iset
Watts   Amp.hrs
The setting will be from 2 single turn pots.
Output voltage is not important and when charging the
LiPo ebike battery I willset it at 54.0V to allow for a little inaccuracy
in the design.
DC supply comes from the left over toroid out of the dead Victron inverter
plus a diode bridge. Put a few secondaries in series and I get 100V at 10A
Cooling will be a ex-PC cpu cooler with fan module.
This will be driven by the nano and a 10K NTC thermistor.
All the usual stuff.
But I have wanted a bigger PS for ages.
And thought why not just make it?
Edited 2021-10-28 17:31 by poida
Posted: 09:48am 28 Oct 2021
Glad to hear JCL are still in business, I was wondering about that.
Big problems in China with floods, power disruptions, and huge discontinuities in the financial system about to fracture mostly caused by a trade war with Australia.
A week or so ago, China sent a nuclear capable ICBM over Sydney, and our navy is now in the Taiwan strait.
We certainly live in interesting times (from an ancient Chinese curse).
Clockmanfr
Posted: 10:51am 28 Oct 2021
My large A4 size PCB's with double copper thickness double sided Power Boards are arriving today, 28th October.
They were shipped, according to the Chinese company i use, shenzhen2u, on the 19th of this month.
Shipped with DHL, to my French house, but because EEC Europe are now implementing all customs checks and VAT charges, a 180gbp order now has another 36 and the standard DHL paper work charge of 40. So another 76gbp for me to pay the DHL company, its getting crazy here, anything made in China is getting very expensive.
poida
Posted: 11:11am 30 Oct 2021
It works.
about 95% conversion efficiency (+/- a couple, likely minus)
30.3V 2.63A in
12.7V 6 A out
The heatsink still cold as after 20 minutes
All I need.
Of course the conversion efficiency will drop a lot when I feed it 100V
and draw 12V output.
I am thinking of switching the various secondary winding's into
the input as the set point voltage changes.
This to keep Vin a bit more than Vout and so conversion efficiency
very high.
Posted: 09:53pm 30 Oct 2021
I use a 1:1 mains isolation transformer, a variac, a bridge rectifier, plus an appropriate electrolytic to do something like that.
0 to over 300v dc at 10 amps.  A bit rough and ready, but for something a bit experimental it can be put together very quickly and does the job.
poida
Posted: 11:53pm 30 Oct 2021
If I had a variac on hand I would have done the same thing
and not the above.
And added a motor to drive it with closed loop control
Murphy's friend
Posted: 08:36am 31 Oct 2021
You must have a decent size variac there Tony, mine is only 500W
Posted: 09:28am 31 Oct 2021
I have one of those too, kind of like an oversized potentiometer.
Then I have my ten amp one which is the most useful.
But also lurking on my bench is a three phase fifteen amp variac with motor drive. Hardly ever use it though, its pretty enormous.
