Local Time 16:59 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Silicon Carbide mosfet range for inverters
zeitfest
Posted: 07:42am 28 Jul 2021
Inverter builders might be interested in these, sounds expensive for experiments though (snap! crackle! pop!)
Solar Mike
Posted: 09:03am 28 Jul 2021
Technology advances.... not sure how many makers will be requiring > 1000v devices for an inverter; look on Microchip's web site and they have none in stock until near the years end.
I'm trying to source some >200 amp mosfets with 3.3v gate drive at the moment, everyone is out of stock, cannot get anything until 2022 - 2023, welcome to the global chip shortage.
Mike
wiseguy
Posted: 10:38am 28 Jul 2021
Ok Mike, I'll bite what are the 200A 3.3V gate drive mosfets for?
I can only imagine that they are essentially a slow on off switch driven directly from the micro? Tell me more I am intrigued, it certainly doesnt sound like a normal inveter topology.
Cheers Mike
Solar Mike
Posted: 12:01pm 28 Jul 2021
Sorry zeitfest, didn't mean to hijack your thread...
  wiseguy said   ... I can only imagine that they are essentially a slow on off switch driven directly from the micro? Tell me more I am intrigued, it certainly doesnt sound like a normal inverter topology.
Yep mostly correct, 3.3v Pico board driving some alarms, one of which is a large truck air horn, draws 50 amps on start @12v, the surface mount mosfet will turn the horn on\off in bursts to prevent its motor over heating; mosfets Ron approx 0.001R. Makes it easier to implement than a large expensive relay, may have to modify the design, not going to wait over a year for parts.
