Local Time 23:06 22 Jun 2026 Privacy Policy
Forum Index : Electronics : CMM2 Construction Guide - wrong switch part # for Mouser/Grayhill
TomTuttle
Posted: 06:09pm 03 Jun 2021
" Right-angle vertical PCB-mount SPDT toggle switch [Altronics S1320, RS 734-7107, element14
9473297, Digi-key EG2364-ND, Mouser 34ASP27T7M2QT]"
The Mouser part # is wrong. 34ASP27T7M2QT is a Grayhill part
34A = mini toggle series
  SP2 = ON - NONE - (ON)   <---  should be ON - NONE - ON
     7 = actuator (bat) style  (it would be close except for the next option)
      T7 = bushing (threaded 15/32-32 -- should be 1/4 non-threaded)
        M2 = PC Mount (vertical not right angle)
          QT = Copper, silver plated RoHS
The correct Grayhill/Mouser part is 34ASP12B4M7QT
The 2 could be swapped for one of the other styles but 2 matches the Digi part# style.
Edit - put this in the wrong forum. Sorry... perhaps a mod can move it.
Edited 2021-06-04 04:49 by TomTuttle
