Local Time 17:39 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Impedance Controlled PCBs
ryanm
Posted: 03:02am 28 Apr 2021
Hi All,
I'm wondering if anyone on the forum has done much work with impedance controlled PCBs. I want to route the ant pin of a RF module to a ufl connector. Googled the basic theory, wondering if there are any traps for new players?
Ryan.
Solar Mike
Posted: 11:27am 28 Apr 2021
  ryanm said  Hi All,
Ryan.
Used to do this sort of thing many years ago, but we had use of a > $30k real time sweep generator and spec analyzer to setup the line for correct response over the frequency range being used. Theory doesn't always match actual measured results, so without the test gear it would be very hit and miss.
Mike
ryanm
Posted: 12:35pm 28 Apr 2021
Very hit and miss you say? With PCBs costing $2ea throw it at the wall and see what sticks is actually pretty feasible I recon.
