Local Time 00:38 23 Jun 2026 Privacy Policy
Forum Index : Electronics : Connecting DC breakers
nickskethisniks
Posted: 01:42pm 16 Mar 2021
Hello,
Does it matter a lot how I connect DC breakers?
I was doing some research for a redesign of my off grid powersystem.
Turns out it does matter, so I need to turn it all upside down again in my head.
But wait current could be negative or positive in my system...help
Something to be aware of:
Breaker on fire
Edited 2021-03-17 00:01 by nickskethisniks
brucedownunder2
Posted: 10:19pm 16 Mar 2021
Hi Nickelnick,
Yes, when Solar installations were sort of new , they bought out some DC breakers that disconnected both positive and negative lead.  Was a bit confusing as they had + and -  symbols at the top and bottom of the individual breakers. So the installer had to figure out which way the current flowed ...
I downloaded from the net some fairly easy to understand wiring diagrams, if it helps you.
(All to do with quenching the ARC that occurs in DC disconnect , with supposedly small rare earth magnets fixed adjacent to the breaker contacts)
never did pull one apart ,but if someone has , post a picture, please.
I'm still using mine , and have not had any problems(that I'm aware of ) ...
So, read up all about them and try to digest how they tell you to connect .
Bruce
Bushboy
