Forum Index : Electronics : Toilet as a subwoofer....
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10084 |
This is really rather interesting: Toilet Subwoofer ![]() Smoke makes things work. When the smoke gets out, it stops! |
| BenandAmber Guru Joined: 16/02/2019 Location: United StatesPosts: 961 |
cool video thanks for posting i had not see any of this guys videos in a long time i had to re subscribe why do they un subscribe you anyway be warned i am good parrot but Dumber than a box of rocks |
The YT algorithm does that kind of thing all the time. I don't think even YT know why it unsubs people from certain channels as the algorithm is now so complex, but I expect it is mainly a side-effect of YT trying to have the algorithm automatically unsub people from conservative channels as they try to prevent conservative channels from being viewed. Just a guess. I could be wrong, but it is backed up by many conservative channels being shadow-banned by the same algorithm. The algorithm quite possibly marked the GARAGE54 channel as a false-positive for a channel that it thinks is conservative and needs to have it's sub numbers 'Adjusted', and so a whole heap of subs are removed by it. This is the problem with algorithms. They make mistakes more often then Humans do most of the time if you over-complicate the algorithm. ![]() Smoke makes things work. When the smoke gets out, it stops! |
