Local Time 17:57 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Up-to-Date Inverter Design
InPhase
Posted: 02:11pm 05 Jan 2021
I've decided to take a stab at one of the inverters the group here has developed. A nano type of about 3 kW @ 24 VDC, I figure. But before I commit, I'll beg the group's opinion and advice. For this project, the battery bank will be 210 AH @ 24 V.
Spec:
24 VDC Input
120/240 VAC Output
2-3 kW Continuous
18 degree C Ambient over the year. Never more than 40.
What I have on-hand and plan to use, until better can be procured, is a battery bank, and a totally potted and enclosed 3 kVA 240/120 V : 32/16 V transformer, what an electrician would typically connect as an autotransformer to slightly raise of lower the line voltage into spec. "Buck/boost". I know it will be less efficient than a toroid, but it will do for now(?). Assorted basic electronic parts in not-too-shabby quantity, including various flavors of analog ICs and digital logic. Tools, o-scope, skills.
I have read for many weeks through the various threads and watched the evolution and iterative updates of some of these builds. For fear of finding a flawed or old design using search, I will ask: what is the up-to-date cutting edge of the Nanoverter software and power board design?
Any other insight and suggestions (besides "Spend more money..") also appreciated.
Posted: 08:30pm 05 Jan 2021
If you have a 32v transformer that is potted, and you cannot change the turns, the minimum dc voltage that can be used will be 32v x 1.414 or 45 volts.
If only half the primary is used, it will work down to 23.6v but at only half rated power or 1.5 Kva.
InPhase
Posted: 10:42pm 05 Jan 2021
  Warpspeed said  If you have a 32v transformer that is potted, and you cannot change the turns, the minimum dc voltage that can be used will be 32v x 1.414 or 45 volts.
There are really two primaries and two secondaries. They can be wired in series or parallel. It's like having two 120:16 transformers. I figured putting 24 volts on the two 16 volt coils wired in parallel would work, even if the output voltage drops as the battery drains. 120/240 is nominal but I don't have a single piece of equipment that would mind 110 or 108.
Posted: 12:13am 06 Jan 2021
Ah !
Then you are definitely in luck.
Parallel up the two 16v primaries and it should work down to about 22.6v dc which is just about right for a 24v lead acid battery.
InPhase
Posted: 01:22am 06 Jan 2021
  Warpspeed said  Ah !
How big of a difference can I expect between this transformer and a toroidal? Besides a lower efficiency, will this transformer behave differently from a MOSFET driving point of view?
Posted: 01:59am 06 Jan 2021
Highly likely that the no load idling power will be a fair bit higher than with a toroid.
You can check that by connecting one of the higher voltage windings of the transformer to a power outlet, and measure the current. That should be a pretty good indicator.
The mosfets could not care less, to them its just a load.
