Local Time 14:33 04 Nov 2026 Privacy Policy
Forum Index : Electronics : F and p wiring slow wind speed
feix62k
Posted: 07:39am 09 Sep 2008
Hi I have 48 STATER FISHER AND PAYKAL smaller wiring 2005 model solid grey magnet type ,I get fairly constant slow wind speed ,what is the best wiring setup recomended I should use .I would rather have consistant power and I will be running 12 volt system not sure if 3 or six blades at this stage. also any good setups for wiring from generator to power outlet thanks felix
dont the days seem lank and long when nothing gos right and everthing gos wrong
