Local Time 18:56 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Stumble across this PCB debug station...
Posted: 08:23am 26 Apr 2020
https://www.thingiverse.com/thing:3615910
Those with 3D printers might like to give this a go. I would probably replace the acupuncture needles with pogo pins.
This is probably a good solution for when you have a logic analyzer attached and the clips keep popping off or occasional shorts between them.
Revlac
Posted: 09:51am 26 Apr 2020
There has been a lot of time spent designing that I bet, I like the idea and it could be handy to hold down a few SMD IC's to aid in soldering.
Might come up with some other uses.
I might have a go at this one later.
Cheers Aaron
Off The Grid
