Local Time 18:55 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Can anyone recommend a reliable source of non fake HY5110's ?
Posted: 09:45pm 01 Mar 2020
As the topic says, anyone had good or bad experiences with HY5110 mosfets.
Has anyone actually tested the drain source breakdown voltage (with gate shorted to source).
mikeb
Posted: 05:48am 02 Mar 2020
Sorry mate,
Haven't even heard of the manufacturer (Huayi Microelectronics) let alone a supplier. I tend to steer clear of any device the usual, reputable, suppliers
(RS Components, Element14, Mouser, Digikey) don't stock.
It's only an N Channel Enhancement Mode MOSFET. Do you have to use it ?
Regards, Mike B.
Solar Mike
Posted: 06:53am 02 Mar 2020
Warp, I got a bunch of them from LCSC Electronics some time ago, haven't had any issues to date, but haven't measured the breakdown voltage. LCSC should be a reputable supplier.
If they are low on stock ask for a quote...
Mike
Edited 2020-03-02 16:55 by Solar Mike
Posted: 08:33pm 02 Mar 2020
Thanks guys.
A friend of mine is having trouble with some HY5110 mosfets purchased from LCSC blowing up, and one possibility of several, is that the mosfets are below spec.
I have in the past had some serious drama that was eventually traced to counterfeit fake parts either not working, or that failed very quickly. I have not so far used HY5110's myself but recall that others here have, so was just wondering...
Have to agree though that LCSC from all accounts so far, seem to be a reputable source.
nickskethisniks
Posted: 11:26am 04 Mar 2020
Maybe irf100p218 is an alternative?
poida
Posted: 11:37pm 18 Apr 2020
  Warpspeed said  As the topic says, anyone had good or bad experiences with HY5110 mosfets.
I just did.
I tested both the HY5110 and the HY4008.
Both tests with about 30mA current limited by series resistor.
HY5110 Vds 109V
HY4008 Vds 85V
The specs for Vds breakdown usually use 250uA.
The test had a 3.2K 7W resistor in series, so I measure  the breakdown voltage
when 0.8V across the 3.2K R
