Local Time 19:05 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Selectronic SPMC241-AU
Mulver
Posted: 12:37am 09 Dec 2019
I picked up a SMPC241-AU Series 1 for next to nothing at a salvage yard. Figuring it would have some nice usable parts inside. It looks unused so I gave it a quick test, AC pass through works fine.
I don't have any suitable batteries so i hooked the DC up to a single 35v panel to see if i can get it to power up.
Lights flash on and pre-charge led comes on then the alarm turns on and nothing else. Nothing stops the alarms and no lights are on except the precharge LED.
Does anyone have any experience with these?
Is it wishful thinking it would fire up off a solar panel?
Edited 2019-12-09 11:02 by Mulver
renewableMark
Posted: 01:11am 09 Dec 2019
manual
Reckon you'll need it hooked up to batteries to test, doubt it works if it was at the junk yard.
Might be lucky.
Cheers Caveman Mark
Off grid eastern Melb
Mulver
Posted: 01:32am 09 Dec 2019
I know its wishful thinking
I just hooked the precharge points up to a 24v power supply and once it charges up all the lights flash on and off then the buzzer goes off and nothing appears to stop it.
Series 1 manual
Edited 2019-12-09 11:33 by Mulver
renewableMark
Posted: 03:13am 09 Dec 2019
Have you tried restore factory default settings?
Cheers Caveman Mark
Mulver
Posted: 06:59am 09 Dec 2019
OI0003_07 004122 SP PRO Manual.pdf
I've tried multiple way to reset and it will not play nice.
Its happy to pass through ac without issue  as soon dc is applied buzzer goes off.
Edited 2019-12-09 17:18 by Mulver
renewableMark
Posted: 08:12pm 09 Dec 2019
Well the manual said to charge the pre charge circuit first, which is what you did.
I can only assume this is like the Ozinverter where you charge the caps via a resistor.
Perhaps open it up and look at that area, maybe a cap went fizz or there is an open circuit somewhere.
Cheers Caveman Mark
