Forum Index : Electronics : Power Inverter Plans
| ArcticCat Newbie Joined: 16/07/2008 Location: United StatesPosts: 6 |
Anyone have plans for power inverters? Id like to know how to build one. Ken |
oztules![]() Guru Joined: 26/07/2007 Location: AustraliaPosts: 1686 |
What topology are you after, and what sort of power range. There are plenty of smaller inverters around for less than the price of the box to put them in. Just to get a decent box built will cost more than a 300 watt unit. .........oztules Village idiot...or... just another hack out of his depth |
I'm looking for 12v inverter plans. As for the resources to build it, I'm not worried about, I just want to know what it takes to build one. This is not a cost savings project. So, is there any DIY inverter plans floating around? Thanks, Ken |
| dwyer Guru Joined: 19/09/2005 Location: AustraliaPosts: 575 |
look mate There one that l found less in two mins on webs site www.electronics-lab.com 500watts low cost 12volts to 220V inverter by author Ashad Mustifa and there are lot more on unless you try and find on webs site is start looking
Dwyer the bushman |
Hi Ken I've built a couple of low power inverters using parts from my junk pile. Each one was only good for 300 watts max, was very inefficient and took several hours to build. These days you can buy an efficient 300 watt inverter for less than $100. If you wanted to build a small inverter as a learning expierence, then as Dwyer says, use google to search for "inverter circuit diagram". But remember unless you have a pile of spare parts/junk, and a few free hours, this will cost you more than a bought one from your local electronics shop. Glenn PS. Found this, its the link to a kit I used for one of my inverters. I used it to drive the final stage transistors and transformer from a old 600 watt UPS. It worked but maxed out at 300 watts. link The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
| Dinges Senior Member Joined: 04/01/2008 Location: AlbaniaPosts: 510 |
I agree with the others, it's hardly economically worthwhile to build a simple inverter yourself when old UPS-es are thrown out by the dozen every day and 'real' (mod. sine) inverters are in the 25-35 E price range. But, I'll admit I have toyed with the idea in the past too. And it could still be a small, educative and practical project for someone new to the field. Here's one design I found a while ago. Can't get more quick & dirty than this. Even no need for soldering. I haven't built it but it should work, at least it did for Harry:
http://web.telia.com/~u85920178/power/psu_inverter_01.htm He claims to have it taken only 15 minutes to wire up.
This is just one example. A few minutes googling should turn up more than you could ever read. |
