Forum Index : Electronics : I fell for a trap, that those more experienced avoid no doubt
Author
Message
poida Guru Joined: 02/02/2017 Location: AustraliaPosts: 1507
Posted: 11:03pm 27 Sep 2019
I discovered that little yellow components are not all the same. I needed 1uF ceramic or monolithic caps, for the nanoverter #3 board
Jaycar frequently has an empty little box, "labelled 1uF monolithic" when I visit. But not last week. Beauty, I'm always needing these. So I got some.
I spent about 4 hours destroying things and discovering #3 nanoverter had a short, across one of the 1uF caps that are located in the charge pump area. (C9) A short that brings 15V supply straight to Vs, being one of the transformer's primary winding connections. Not a good thing as it happens.
I blew my unbreakable test inverer board, taking 16 high quality and costly IR3808 out. Why did the 1uf mono go short?
Eyesight, even with spex nowadays is not good for me. Close examination showed the 1uF mono was in fact 1uF 35V Tantalum. Tants don't like reverse polarity much and it was 50/50 chance which way I placed them on the board since I "knew" they were mono/ceramic and so unipolar. Except they were NOT mono/ceramics.
I had placed 6 of these on nano #3 and all had to come out.
One thing I saw with the Tant caps in this application was the nanoverter's AC voltage reading on the LCD dropped, and dropped, continually at about a -2V/second rate. The DVM showed a steady 230V output. I had a Tant cap stuffing up the ADC reference voltage too.wronger than a phone book full of wrong phone numbers
Solar Mike Guru Joined: 08/02/2015 Location: New ZealandPosts: 1255
Posted: 11:38pm 27 Sep 2019
Tough luck there Poida, I gave up using tant caps anywhere near power supplies years ago, they have such a low impedance that current surges destroy them and in doing so they short circuit the power supply. Polypropylene film caps are the ones to use for current discharge applications as in mosfet drivers, they self heal.
Cheers Mike
noneyabussiness Guru Joined: 31/07/2017 Location: AustraliaPosts: 527
Posted: 09:36pm 28 Sep 2019
And regularly catch fire if damaged.... personal experience, similar to you poida...I think it works !!
Warpspeed Guru Joined: 09/08/2007 Location: AustraliaPosts: 4406
Posted: 10:32pm 28 Sep 2019
Same here, very frustrating. A while back I bought a huge quantity of Chinese low esr electrolytics, 1uF and 10uF, and have had zero failures since.Cheers, Tony.
tinyt Guru Joined: 12/11/2017 Location: United StatesPosts: 564
Posted: 03:57am 29 Sep 2019
Got used to aluminums with bar markings for negative terminal. Had one of those surface mount tants soldered in reverse, because the bar marking is for the positive terminal. It did not explode, it smoked first then glowed red hot and popped from the PCB, almost hit me in the face.
