Local Time 19:29 04 Nov 2026 Privacy Policy
Forum Index : Electronics : Looking for Relays
Davo99
Posted: 09:35am 23 Jul 2019
My air con has had a partial failure I have traced back to a relay. Daikin don't do the board anymore so it's a repair and hope job.
The relay number is AJK3341.
Only ones I can find online are on Allie and take 30-50 days to get here.
Wondering if anyone knows if there is a conversion to another number or another source that may be faster to get these from. There are 5 on the board so may as well do them while it's out.
Thanks.
dwyer
Posted: 10:04am 23 Jul 2019
Relay is basicing very common around however can be order in Sydney and contact them
Phone: 1300 656 636
Fax: 1300 656 696
Email: ozorder@rs-components.com
Web: au.rs-online.com
Good luck
Davo99
Posted: 10:38am 25 Jul 2019
Been trying to reply for days but my posts wouldn't go through for some reason even though I tried the main compute, my laptop and tablet. Ah Well.
I went to the RS site and put in the relay number but it says not found. Does one have to log in with an account for the search to work or do they just not have them?
Seems I'm still looking for them. Edited by Davo99 2019-07-26
Chopperp
Posted: 10:54am 25 Jul 2019
There are problems with the Forum. Gizmo Glenn has put up a few notices about it.
You do not have to log into RS for search to work. The relay in question is discontinued & they obviously do not have them.
One of the websites I quickly glanced at after a search gave the specifications for it so you should be able to find something similar but may require mods to fit it.
ChopperP
Boppa
Posted: 10:59am 25 Jul 2019
It's a 12v relay, contacts are 3A at 240v but cant tell if it's a spst or spdt (appears to be a spst, but check yours to confirm)
Should be easy enough to find a replacement from RS- measure the pin spacing's and find a 12v relay with 3A or higher contact ratings that fits the holes...
