Local Time 14:58 23 Jun 2026 Privacy Policy
Forum Index : Electronics : What do you think about this inverter ?
hary
Posted: 02:17pm 03 May 2019
This one
It has quite big toroid, no ?
BenandAmber
Posted: 09:19pm 03 May 2019
I don't understand is this a inverter or a welder or both
And I didn't see where anybody stated the price
yahoo2
Posted: 03:19am 04 May 2019
13 cm high by 18 cm diameter
I think it would run hot at 2000 watts and 24 volts
a pair of them would be OK.
hary
Posted: 07:39pm 04 May 2019
37kg of toroid transformer is not enough for A 5kW inverter ?
yahoo2
Posted: 02:55am 05 May 2019
if its 37 kg it should be fine.
I looked at the spec sheets and the photo and decided it was a smaller unit.
I missed the bit where Dave said it was 5kw.
perhaps their winding technique is better than mine, my 35 kg one looks like it ate all the pies. and it is not slim and square sided at all.
BenandAmber
Posted: 03:15am 05 May 2019
Unless the guy that I brought my Transformer off of was just guessing 52 lb is 5000 watts
that could be the case because the wires are so big it makes me think it's bigger then 5000 WattsEdited by BenandAmber 2019-05-06
