Forum Index : Electronics : $100 hand-held 2-ch 1MHz scope....
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10084 |
As a little follow-on from my other thread on cheap scopes, I found this one today. This little unit is about $100, two-channel, 1MHz bandwidth(so 5x better bandwidth then the cheapies in the other thread), comes with silicone test leads and seems quite nice, really. ![]() Also has a function generator built-in, so you can do sine, square and triangle wave generation. ![]() LINK TO THE SCOPE VIDEO REVIEW OF THE SCOPE ....really thinking about getting one of these to play with. Smoke makes things work. When the smoke gets out, it stops! |
| davef Guru Joined: 14/05/2006 Location: New ZealandPosts: 499 |
Watched the video. Too bad he didn't see what a 100kHz square wave looked like. |
Yes, I am trying to find more review videos on this thing. Smoke makes things work. When the smoke gets out, it stops! |
