Local Time 21:56 04 Nov 2026 Privacy Policy
Forum Index : Electronics : ACS712 Current sensor: Kalman filtering
LadyN
Posted: 08:37pm 28 Jan 2019
Anyone here worked on Kalman filtering on, say, an Arduino?
I am thinking of starting up with ACS712 Current sensor and hoping to handle noise using Kalman filtering
zaphod
Posted: 07:03am 29 Jan 2019
I have experience of that particular sensor, I don't know what your application is but I used it in a 1Kw switching converter and found it VERY sensitive to external magnetic fields, in the end I replaced it with a LEM that IMOP is a much better device although more expensive and I don't have to filter the LEM at all even though it's in exactly the same situation.
Cheers Roger
1Kwp DIY PV + Woodburner + Rainwater scavanger :)
LadyN
Posted: 10:44pm 29 Jan 2019
  zaphod said   I have experience of that particular sensor, I don't know what your application is but I used it in a 1Kw switching converter and found it VERY sensitive to external magnetic fields
OK, do you have the noisy measurements?
What kind of errors/variance were you getting?
  zaphod said  in the end I replaced it with a LEM that IMOP is a much better device although more expensive and I don't have to filter the LEM at all even though it's in exactly the same situation.
Do you have a link to look at?
zaphod
Posted: 11:26am 30 Jan 2019
Its not a matter of accuracy, it's the sensitivity to noise that I could not filter due to the bandwidth requirements of the design.
The LEM devices are here https://www.lem.com/en/product-list?measurement=52 I happen to use the HLSR series but there are many to choose from.
Cheers Roger
LadyN
Posted: 02:37am 31 Jan 2019
  zaphod said   Its not a matter of accuracy, it's the sensitivity to noise that I could not filter due to the bandwidth requirements of the design.
I have a LOT to learn, so can you explain this as I don't understand how inability to filter due relates to the bandwidth requirements.
It may happen that your explanation might be a whole book, but in that case can you condense it down to an example and I will try and learn any formula and equations you use in that example.
Would it be fair to say that their products, eg: https://www.lem.com/en/ho-200pw0400
Is a PSU and uC wrapped around a sensor like: https://www.aliexpress.com/item/1pcs-lot-free-shipping-LA25-NP-LA35-NP-LA55-P-SP2-LA55-P-HTB100-TP-SP3/32964307267.html
Thank you again. VERY MUCH
zaphod
Posted: 07:07am 31 Jan 2019
  LadyN said  I have a LOT to learn, so can you explain this as I don't understand how inability to filter due relates to the bandwidth requirements.
The bandwidth required is about 100 times 50hZ in this particular application to ensure accurate reproduction of a 50hZ sine without generating excessive harmonic distortion, any post sensor filter introduces phase lag that is difficult to compensate elsewhere and so it's simply better to eliminate these problems at source (use a better sensor). But if your application is not sensitive to these issues then try a cheap sensor and post filter :)
  LadyN said  Would it be fair to say that their products, eg: https://www.lem.com/en/ho-200pw0400
I have no idea, there is no product information nor specification on that site, I don't use ali express as it tends to be grey market.
Cheers Roger
