Local Time 01:14 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Chinese wind controllers?
druist
Posted: 02:00am 18 Oct 2017
in my haste i bought one of the cheap ebay controllers https://goo.gl/Z8n8oj
a) do they work ok?
b) can i somehow add a dump load eg an electric heating element?
This is for a HAWT system with 12v treadmill motor.
flc1
Posted: 09:00pm 18 Oct 2017
Hi Druist, it appears that you cannot connect anything to that controller, maybe you could consider somthing like this Xantrex controller?,or somthing similar, its a bit more usefull for what you need
http://www.ebay.co.uk/itm/Xantrex-C35-Solar-Wind-Turbine-Generator-Charge-Load-Controller-UL-Listed-/251430323592?epid=1 923828464&hash=item3a8a6a4588:g:Z~YAAOxy63FS3YM7
druist
Posted: 02:49am 19 Oct 2017
  flc1 said   Hi Druist, it appears that you cannot connect anything to that controller, maybe you could consider somthing like this Xantrex controller?,or somthing similar, its a bit more usefull for what you need
thanks - do you know anything about this one?
https://goo.gl/f837bj
flc1
Posted: 01:29pm 19 Oct 2017
Yea I used one of these controllers on my other older turbine when it was running into batterys, worked well,
Im sure there are other makes of controllers out there that are probly better, but I never had a problem with my xantrex controllers.
And they are usually not too expensive to buy.Edited by flc1 2017-10-20
fillm
Posted: 12:05am 20 Oct 2017
That is not a wind turbine controller , it is only a over voltage protection or dump load control that sees battery voltage and dumps it to a resistor if to high . You will still need rectifier and dump resistor .
It will work and is a very simple device, These days there is a lot better out there but again depends on our budget.
