Local Time 04:02 12 Nov 2026 Privacy Policy
Forum Index : Windmills : My degree project
z3ronim
Posted: 02:14am 22 Mar 2008
hye, im naim from national defence university of malaysia..im am building a project for my degree project which is Rainstrorm Alarm System...actually im already ask this question to the administrator at "About us" but no replies..
firstly, my project is quite same like PicLog (http://www.thebackshed.com/Windmill/PicLog.asp)..but my project is simple because im just collecting the windspeed only..so i dont need the voltage and AC measurement..
so my question is how to simply the circuit in PicLog because im quite dont understand about the circuit and what component to use because the circuit just show the picture not the series or model of the components..
so can anyone help me?..im running of time because the presentation day is just around the corner ...
Posted: 02:34am 22 Mar 2008
Hi Naim.
We need some more info. If you just want to measure windspeed then you wont need the PicLog.
What do you want as the output, a variable voltage, or a 1/0 output once a wind speed is reached?
z3ronim
Posted: 02:21am 23 Mar 2008
the output= wind speed (rpm)
im using cpu fan cooler to be as anemometer..
so when the wind speed reached at maximum which it means can harm people it will sound an alarm (im using a buzzer)..
Posted: 03:00am 23 Mar 2008
The little fan, once you remove the electronics and add a diode, will generate a voltage proportional to wind speed, though I wouldn't use it as a accurate measuring device.
What you want is a simple circuit that will switch output once this voltage rises to a preset level. A op-amp comparator is all you need, see here for a crash course in op-amps. http://web.telia.com/~u85920178/begin/opamp00.htm
z3ronim
Posted: 03:03am 23 Mar 2008
Gizmo,
so i cant use your PicLog although i simplify it?
do you have yahoo messenger?
i think its easy to chat
Posted: 05:45am 23 Mar 2008
Hi Naim
The PicLog is overkill for what you want, its like using a PC to work out 1+1=2
Look into using a op-amp like I suggested, it will work perfectly for what you want. Simple and reliable.
Yahoo Messenger? Nah dont do the chat thing.
z3ronim
Posted: 08:20am 23 Mar 2008
ok...anyway thanks a lot..
i will look on it
by the way,its means i dont needs to use PicAxe anymore right?just build up the circuit in that web?
and how i need to program it,it is ok if i use the programming editor for PicAxe to porgram the cicuit??
Posted: 10:43am 23 Mar 2008
Hi Z3ronim,
You sound like you intend to try and program the OP-amp circuit?
Posted: 01:08pm 23 Mar 2008
Hi Niam
It sounds like you are new to electronics. I would suggest you contact someone in your university who is experienced in electronics to help you with your project. The "Op-Amp" does not need to be programmed.
z3ronim
Posted: 01:33am 24 Mar 2008
i know about the op-amp..but im building a sytem..not just a device..
