Local Time 03:38 12 Nov 2026 Privacy Policy
Forum Index : Windmills : F&P stator
backcam
Posted: 08:48am 08 Jan 2008
Does the f&p stator need any weather protection?
Posted: 09:19am 08 Jan 2008
Hi backcam
A coat of varnish on the stator coils and exposed steel laminations stops corrosion. It's also a good idea to paint the plastic hub, UV light will cause the plastic to break down quickly, depending on the model and plastic used. The white plastic is the most sensitive to UV.
