Local Time 01:44 12 Nov 2026 Privacy Policy
Forum Index : Windmills : fisher & paykel on mppt?
Kris
Posted: 01:40pm 23 Feb 2016
Hi everyone
Has anyone used the fisher and paykel smart drive without rewiring and running it through a mppt instead ?
I know it develops some hi voltage. Can it be split into two and then run through the mppt or even rewired into delta and then put through the mppt.And if so would there be some compromise between current and voltage in the outcome? . Any ideas would be appreciated.
Kris
govertical
Posted: 01:57pm 23 Feb 2016
Hi, where is the MPPT coming from? The problem is the max VOC at the input MPPT.
Kris
Posted: 02:32pm 23 Feb 2016
Hi
The voltage going drive Ihe mppt is rectified dc from the smart drive, the mppt/controller charges the battery's.
My understanding of mppt is that they can handle hi input voltage , correct me if I'm wrong.
Also I'm running 1 kw of solar at 48v to charge a 12 v battery bank.
My mppt can handle up to 150v dc input to charge battery banks from 12 to 48v, this is done by selecting
Your nominated battery voltage at the mppt.
I though if the smart drive can be directly fed into a mppt then it may say time and effort rewiring the sd stator.
Kris
govertical
Posted: 08:13pm 23 Feb 2016
MPPT driving a 50 watt load
Hi , I designed my MPPT to handle a max VOC 450 Volts DC. Depending upon the RPM of the F&P the un-altered stator can produce a output voltages in excess of 150 Vdc.
Do you have any photos of your MPPT?
What is the max RPM of your windmill?
You have make to sure the DC no load output of your F&P does not exceed 150 Vdc.
