Forum Index : Windmills : 3 Phase Voltage Quadrupler
leftcliq
Posted: 01:15am 16 Dec 2015
Hi Guys,
Always a great forum.
I'm using a F and P smart drive motor and I am looking for a 3 phase voltage quadruler circuit. Has anyone had any experience with this motor and this type of circuit? I have been through the previous 42 page forum post but maybe a missed a page. I know this is an old issue and some of the images are missing.
Or is the bottom circuit on Gordons Cap Mod Circuit a voltage quadrupler circuit?
I would really appreciate any feedback or experience.
-Dale.
Posted: 01:34am 16 Dec 2015
Hi Dale
Its a 3 phase voltage doubler, in parallel with a standard 3 phase rectifier.
I heard Gordon did experiment with triplers and quadruplers, but the gains are small, plus its a real mess of rectifiers and capacitors.
I use a doubler on my OEM windmill, similar AC frequency to a F&P, and happy with the results, especially in low winds.
leftcliq
Posted: 01:45am 16 Dec 2015
  Gizmo said   Hi Dale
Hi Glenn,
Thanks for the response. I have a voltage tripler that works fine and I think it was Gordon's circuit.
Thanks for the voltage doubler in parallel with a 3 phase rectifier. Is the attached image what you are referring too: Sparweb
Thanks,
Dale.
leftcliq
Posted: 02:24am 20 Dec 2015
  leftcliq said
  Gizmo said   Hi Dale
Hi Glenn,
Thanks for the voltage doubler in parallel with a 3 phase rectifier. Is the attached image what you are referring too: [URL=http://www.sparweb.ca/Diary/Cap_Test/Gordons_Cap_Circuit_R14.gif]Sparweb[/URL]
Thanks,
Dale.
Hi Glenn,
Can you please let me know if the circuit I have a link to above is the quadrupler circuit?
Dale.
