Local Time 01:58 12 Nov 2026 Privacy Policy
Forum Index : Windmills : 3 phase turbine testing
Jules
Posted: 04:55pm 20 Mar 2015
Can anyone tell me how to test a 3 phase turbine for a dead short?
I unfortunately managed to jam one of my connections in the tower hinge last time i raised the turbine, took 3 months to break down but I'm assume one of the windings has burnt out any ideas people?
VK4AYQ
Posted: 09:20pm 20 Mar 2015
Hi Jules
Some more details needed.
Is the turbine star or delta connected
Do you have it down, what voltage is it, is there any shorts to earth on the down phase.
Is the wiring to the turbine intact, is the restifier still working on all phases.
Are the rotator brushes intact
Have you done voltage checks have you done low ohms check.
All the best
Foolin Around
