Local Time 01:58 12 Nov 2026 Privacy Policy
Forum Index : Windmills : solar controler
trout
Posted: 07:54pm 28 Dec 2014
Hi there I need to bye a new solar controler something that can handle 4x130w panels .does anyone know a good quality one?
Posted: 02:44am 29 Dec 2014
One would expect it to be a better question to be asked in the solar section of the forum than under "Windmills".
fillm
Posted: 06:14pm 29 Dec 2014
Yep Kind of agree there Pete,
Trout, system voltage is really good to know as amps could be 43A @ 12V or 11@ 48V.
I only recommend one brand Aus Built- Plasmatronics PL series if you want to look after you batteries. so if your system is 12 V a PL60 and that will give you room to add a couple more panels.
If you want MPPT then you will be looking at around $900 for a good controller
