Local Time 03:10 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Question from newbie
robbie
Posted: 11:19pm 05 Sep 2007
Hi, just wondering if the battery and motor on the 3mm ply wood need a cover over it to protect it from the weather(water)on the mini windmill
maaca
Posted: 11:37pm 06 Sep 2007
Hi Robbie, I have just completed my first windmill and will post it on the forum later.I have covered everything to make it as weather-proof as I could.There is control gear in there as well, and although only $75.00 NZ it takes a while to assemble and fit etc.A battery probably wouldnt hurt too much but in my case Im in a coastal and salty enviroment.To my mind water intrusion into any electronics and or electrical gear is highly un-desireable. Hope this helps a little and good luck with your project. Maaca.
