Forum Index : Windmills : Blades for Dunlite 2.5kw
Trev
Posted: 10:19am 25 Aug 2007
Hi All,
Hoping someone has some info on the Dunlite wind gen's. A fellow has a 2.5 kw head but no blades. Can anyone help with what length blades this should have....please
Trev @ drivebynature.com
BUGS
Posted: 09:53pm 25 Aug 2007
Hi Trev, I have info from Electronics Australia July 1978 Mag.The 2Kw employs a standard 3 blade 4 metre diameter prop.Output voltage can be 12v and 110v.The mag
has a piture if that helps.May be able to copy and send.
Hope that helps. Regards Ivan
BUGS
