Local Time 02:18 21 Sep 2026 Privacy Policy
Forum Index : Windmills : Earth Wire
leftcliq
Posted: 01:35pm 21 Sep 2014
Hi Guys,
Great forum. I have a 7 phase F&P motor working ok, my question is: Do I need the earth connection on the motor? The rectified AC delivers Pos and Neg so is the earth required?
Dale.
Posted: 03:05pm 21 Sep 2014
Hi Dale
How are you using the output of the F&P? Battery charging?
leftcliq
Posted: 07:05pm 25 Sep 2014
  Gizmo said   Hi Dale
Does it matter how the output is used? I am charging up capacitors, yes battery charging.
Also, with the rewired 7 phase 60s, it is cogless. As I am after more amps, could I rewire it to a 24V system and still remain cogless? I know that amperage is the load demand on the motor. Currently, When I turn the motor by hand I am getting up to approx 35V and easy to move. If I drop this down to between 12-24V, will this motor be easy to turn or will the added current drain be too much to turn?
Hope this makes sense.
Dale.
leftcliq
Posted: 07:21pm 25 Sep 2014
  leftcliq said
  Gizmo said   Hi Dale
Dale.
Rather than going down this path, have you used the improved high power rotors on the type 4 60s wired as 7 phase? Will there be an extra load on the motor to deliver the higher power on the cogless system?
-Dale.
