Local Time 02:08 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Foundations
Jules
Posted: 07:58pm 05 Aug 2014
I have a 1.5 kw turbine on a 6m guy wire tower. Some of the foundations have started to pull out of the ground due to the amount of wet weather we've had lately. The current foundations are about 700mm deep by 400mm circumference. Wondering how I should proceed option 1 remove the old foundation and start over or option 2 excavate around the existing foundation and dump another couple hundred kg of concrete around it. Either way I'm prevented from going deeper due to a layer of bed rock. Any suggestions?
Julian
fillm
Posted: 08:07pm 05 Aug 2014
Do What they to with big tents , 2 smaller foundations Behind and at 60Deg, then tie these to the existing guy anchor point is one method.
There are many ways but weight is not the answer , surface area is - even a sleeper trenched in behind with a small link trench to allow it to be tied to the existing with as little ground disturbance as possible.
The more useful information would be the height of the top guy attachment points , how many ,and the distance out from the tower base to the anchor points then the Dia of the mill. Edited by fillm 2014-08-07
Posted: 08:20pm 05 Aug 2014
I have the same problem, my anchor points have moved about 6 inches in the last 2 years. How far from the tower footing to the guy wire anchor points? Would it be practical to dig a trench a few inches deep between each anchor and the tower, and drop in a length of galvanised pipe, with a blob of cement at each end to bond with the existing foundations. Sort of like spokes of a big wheel. It would stop the anchor foundations creeping towards the tower. Just an idea.
Posted: 12:31am 06 Aug 2014
Glenn, The forces on the guy wire anchor decrease with the distance to mast base but there is obviously a practical limit.
Often suggested is a 45 deg angle for the guy, so distance from mast base = attachment height on mast.
I do not think your anti pulling pipe in a trench idea has anywhere near the benefit of the sub anchor points fillm suggests. I would go with the latter and use star pickets hammered in at an angle with the top of the picket further from the mast base than its pointy end.
You might only need to do that in the direction of the strongest winds at your location.
jkis
Posted: 12:38am 06 Aug 2014
if your down to good rock, would it be worth it to put in some dyna bolts into it,
then cover with concrete to ground level.
cheers stuart
norcold
Posted: 02:58pm 06 Aug 2014
From my tank stand building days, I built 450mm dia X 1m deep concrete foundations in decomposed granite "sand", 4 on each tower, 6m out from upright. Highest tower is 12m with 4 X 3 Guys anchored to foundations. Probably an overkill in my low wind site, biggest problem I have is the 5mm galv wire rope guys, although they are a Whites Wires product they have developed rust problems. I think they may have just passed closely by the galv process Have replaced one set already with 3mm stainless multistrand wire, I luckily scored cheaply.
The suggestion to use dyna bolts on rock is probably the best way to go if you cannot get depth.Edited by norcold 2014-08-08
Vic
Jules
Posted: 03:08pm 20 Aug 2014
Thanks for your advice ended up getting an excavator out and putting over a ton of concrete in each pier problem resolved for now.
