Local Time 02:38 12 Nov 2026 Privacy Policy
Forum Index : Windmills : Homemade wooden blades seal
charlie_ruizpr
Posted: 03:12pm 28 Jul 2013
I have made 10.6' 3 wooden blades on a jig with a saw and have had them stored in the shed for 4-6 months because I do not know what is best used to seal them from the elements. I have seen people use fiberglass resin and it adds weight to the blades and also seen people using varnish but they should re varnish every 14-18 months. What would you recommend I use to seal them? Could Thompson's WaterSeal 1-gal. Waterproofer Plus Clear Wood Protector work well?
Posted: 03:25pm 28 Jul 2013
I would be looking at marine wood varnish or an epoxy type product. These are made to handle harsh conditions, the epoxy types may be better at resisting erosion that will occur.
Posted: 10:19pm 28 Jul 2013
One thing to watch is the leading edge. Bugs and dust can wear through the coating over time, and then water can get in between the wood and paint/resin/epoxy, which leads to delamination.
I remember one common fix was to run aluminium tape along the leading edge to protect it, but I don't know if this is still done.
What ever you coat the blades in, I would still want to take them down and inspect the leading edge for wear once a year or so.
charlie_ruizpr
Posted: 02:30am 29 Jul 2013
Well thanks for your help i will look into it
yahoo2
Posted: 04:42am 02 Aug 2013
If you are looking for a clear coat, I would go with two coats of a standard thickness marine epoxy resin with two coats of a traditional oil based varnish or polyurethane uv blocker (clear coat) over the top to stop yellowing. warming the epoxy and the blades should thin it enough.
If the epoxy is sold as penetrating it is probably poor quality epoxy with a lot of solvent in it, the finish will be quite porous and let moisture in.
I struggle with brush marks with polyurethane top coats even with a slow reducer, better to spray it on.
