Local Time 00:11 12 Nov 2026 Privacy Policy
Forum Index : Windmills : How to insulate damage copper wires
ozetrade
Posted: 07:33am 31 Oct 2005
Hi Peoples
I've just started my second F&P rewire. I decided I would grind the terminal post's down to make a neat finish. When I did this the grinder made contact with two of the wires - just enough to take the dark copper colour off.  Unfortunately they are under the initial start of the rewire.
What can I do reinsulate these wires?
Thanks, Greg
Greg
Just North of Brisbane in Redcliffe
OZeTrade.net
Posted: 11:24am 31 Oct 2005
Hi Greg
Go and buy ( steal from the missus ) some nail polish. Its the same sort of stuff and works a treat. If you have nicked the wire deeply, ie took a chunk out of it, use your soldering iron and solder the wire back up to its original thickness before applying the nail polish.
Glenn.
ozetrade
Posted: 11:38am 31 Oct 2005
Thanks Glen, I thought I'd really stuffed it - neat trick.
Greg
Greg
OZeTrade.net
