Local Time 03:38 12 Nov 2026 Privacy Policy
Forum Index : Windmills : prospective generator
curiosity
Posted: 12:11pm 10 Apr 2012
I have an aircraft generator very similar to http://us.ebid.net/for-sale/aircraft-d-c-generator-type-p-mf rs-43879429.htm and was wondering if it would make a decent wind generator?
Posted: 01:15pm 10 Apr 2012
Hi Curiosity
Nah, it would be pretty hopeless. It looks like a series wound generator, and reading the description, it supplies 28 volts at 5,000 to 10,000 RPM. Thats about 20 times to fast for a wind turbine.
It would, however, make a mean motor for a kids scoota!
yahoo2
Posted: 01:26pm 10 Apr 2012
spec plate says output 200 amps and rev range 5000 to 10,000 rpm. they make good motor driven chargers for big 24 volt battery banks but need good support bearings and at least a 2 belt pulley.
curiosity
Posted: 01:56pm 10 Apr 2012
  Gizmo said   Hi Curiosity
I realize a windmill would never spin that fast. I wouldn't be spinning it directly from the blade head. Possibly from a stepped gear or pulley set up to achieve the speed required
Posted: 02:10pm 10 Apr 2012
A 20:1 gearing ratio is a *very* big ask for that requirement. Personally, I would not bother with bigger than 6: 1 ratios which can just about be done with a single reduction.
curiosity
Posted: 12:32pm 12 Apr 2012
Thanks guys. I thought maybe a vawt would do it but 6:1 is a far cry from 20:1
Rastus
Posted: 12:08pm 14 Apr 2012
Hi Glenn,
Using 5 of the Goe222 blades,can you provide a guestimated Rpm capped speed,using a diameter of your choice,please? I havn't checked,but I vaguelly remember seeing a 5 blade mill on an earlier thread someware and I'm hoping you can fill in some details.Cheers Rastus
