Local Time 04:03 12 Nov 2026 Privacy Policy
Forum Index : Windmills : blade length
Eddie
Posted: 11:15pm 06 Feb 2012
I have a small 125 watt wind generator.I originaly had six 12 inch long pvc blades on it,but it took a pretty strong wind to get it going.
I made three 19 1/2 inch blades for it and it gets going in lower winds,but it doesn't turn quite as fast.
My question is does anyone think if I shortened the 19 1/2 blades a little would they turn faster?
VK4AYQ
Posted: 11:45pm 06 Feb 2012
Hi Eddie
Shorter blades will turn faster but they collect less energy from the wind so you need to balance the two effects.
http://www.alton-moore.net/wind_calculations.html
Have a look at the Altons site as it will give you and idea on blade sizing.
All the best
Foolin Around
Eddie
Posted: 02:41am 07 Feb 2012
Thanks Bob for the link,had some good info.I guess I'll just to have do some experimenting,I've got plenty pvc.
I,ve got smaller one I built with a 12 volt motor that I put a model airplane prop on,It spins like crazy but it's a high speed motor and will never see 12 volts.I only built it because I had all the parts I needed for it laying around.
