Local Time 05:00 12 Nov 2026 Privacy Policy
Forum Index : Windmills : EMC Compliance required?
darcyrandall200
Posted: 05:29am 19 Jun 2011
Hello there,
I am looking at getting my wind tubine connected to the grid.
Probably a Windy Boy inverter and some DIY dump load/charge controller/overvoltage protection etc
I wish to save money. I am hoping I can make the dump load/charge controller myself, probably a variation of this
http://members.rennlist.org/warren/dumpload.html.
Is it necessary to get EMC/safety compliance for a circuit such as this?
When is it necessary?
Thankyou.
Regards Darcy Randall, Perth Western Australia
Posted: 10:04am 19 Jun 2011
Hi Darcy
It depends on the voltages you are paying with. For 12v and 24v I'm pretty sure you can do as you like, as its not a lethal voltge. Its like wiring up the spotlights on the car, anyone can do it. Mind you, if you short something out and burn down the neighbours house, you'll still be in trouble. 48volts and up I think there are some regulations on what you can and cant do without some sort of qualification or training. Maybe someone else could shed some light on the subject.
A lot of it also comes down to common sense. Play it safe with anything electrical.
Xmaswiz
Posted: 11:20pm 23 Jun 2011
  darcyrandall200 said   Hello there,
http://members.rennlist.org/warren/dumpload.html tried the link, but would not work, is anything missing?
Santa Maria, CA.
Noel
Perry
Posted: 01:04am 24 Jun 2011
Hello,
Why would you need a dump load and charge controller if you are thinking of grid connecting. Those are for battery maintenance.
Think about it, why waste the energy as heat in a dump load when you are set up to sell it back for money?
Perry
darcyrandall200
Posted: 01:35pm 24 Jun 2011
If it is necessary to disconnect the AC side of the inverter eg for maintenance on the lines then it is neccessary to provide a dump load so the mill does not spin out of control.
If My turbine is producing more power than my inverter can supply to the grid then the dc volts will rise. I will need to switch in the dump load to slow the Mill.
Thankyou.
Rastus
Posted: 12:51pm 25 Jun 2011
Hi Darcy,
Just a thought,the compliance of the installation is probably going to be inspected more so than the components.Even on a commercial level occassional duds are distributed and require recall/replacement.Where someone is considering making their own controller ect. they would have a level of comprehension and competence needed to evaluate the project.That is unless they are a total "Jock" in which case they'll unforunately get into trouble before to long.Cheers Rastus
KarlJ
Posted: 07:14am 26 Jun 2011
Perry
he's right, I have two independent dump loads ontop of the grid connection
one breaks, batt volts rise again 2nd dump load kicks in.
Even more critical without batts to stabilise things.
